I am beginning phase one and will be updating engine limits into my Dynon EMS. Can anyone supply the max, normal and min for an IO360M1B with constant speed prop for oil temp, oil pressure, fuel pressure, CHT, etc? I have some of the numbers from the pilot operator's manual and am looking for a complete set.
Do you have a Lycoming Operating Manual? They should all be listed in there.
From my Lycoming Operating Manual O-360, HO-360, IO-360, AIO-360, HIO-360 & TIO-360 Series, Part No. 60297-12:
Oil Temp: Desired: 160 to 180*F depending on the OAT. 245*F Max
Oil Pressure: Max 95, Min 55, idling 25 PSI
Fuel Pressure: Max 35, Min -2 (I don't understand the -2 minimum, but that's what is listed in the manual.)
CHT: 500*F Max (For max service life, maintain cylinder heat temperature between 150*F and 400*F during continuous operation.)
Oil temp for takeoff can be performed after you can add full throttle without the engine stumbling, no minimum oil temperature is listed.
(That said, I wait until all CHT's are 200*F before taxiing.)
