I’m having an electrical issue, looking for some advice.
Dynon D180, 60 amp alternator, separate solid state regulator, PC680 AGM battery.
Recently on flights after about 15-20 minutes my charging amps is all over the place, going from 5-15 amps fluctuating, voltage stays constant at 14.5. Went thru all the connections, battery, alternator, VR, Dynon180, the Dynon Shunt, everything was cleaned and corrosion inhibitor applied. Normal charging is usually pretty steady at about 5-8 amps.
I’m thinking the battery which is only 1.5 years old may be low at its reading 12.-12.5 when fully charged. Should be closer to 13 volts.
Ordered a new earthx as was looking for an excuse to put one in anyway.
Looking for any ideas for where else to look if it’s not the battery.
N601XP
N601XP
