Saudi Crown Prince Abdullah heading to Texas (Dallas and Crawford) for summit
04/24/2005 17:15 - 04/24/2005 20:45
Current TFRs:
http://tfr.faa.gov/tfr/list.jsp
5/3144 - FLIGHT RESTRICTIONS DALLAS, TEXAS, APRIL 24, 2005 LOCAL. PURSUANT TO TITLE 14, SECTION 91.141 OF THE CODE OF FEDERAL REGULATIONS, AIRCRAFT FLIGHT OPERATIONS ARE PROHIBITED WITHIN THE FOLLOWING AREA(S) UNLESS OTHERWISE AUTHORIZED BY ATC. 3.0 NMR BLW 3000 FEET AGL OF 325050N/0965106W OR THE CVE129003.7 FROM 0504241715 (1215 LOCAL 04/24/05) UNTIL 0504241805 (1305 LOCAL 04/24/05), 3.0 NMR BLW 3000 FEET AGL OF 324811N/0964825W OR THE CVE131007.2 FROM 0504241735 (1235 LOCAL 04/24/05) UNTIL 0504242025 (1525 LOCAL 04/24/05), 3.0 NMR BLW 3000 FEET AGL OF 325050N/0965106W OR THE CVE129003.7 FROM 0504241955 (1455 LOCAL 04/24/05) UNTIL 0504242045 (1545 LOCAL 04/24/05) WIE UNTIL UFN
5/3162 - PART 1 OF 4 FLIGHT RESTRICTIONS CRAWFORD, TEXAS, APRIL 22-26, 2005. PURSUANT TO TITLE 14, SECTION 91.141, OF THE CODE OF FEDERAL REGULATIONS, AIRCRAFT FLIGHT OPERATIONS ARE PROHIBITED WITHIN 30 NMR BLW FL180 OF 313445N/0973200W OR THE ACT241014.4 FROM 0504221800 (1300 LOCAL 04/22/05) UNTIL 0504261630 (1130 LOCAL 04/26/05). A. ALL AIRCRAFT OPERATIONS WITHIN 10 NMR ARE PROHIBITED EXCEPT FOR: 1. LAW ENFORCEMENT AND MILITARY AIRCRAFT DIRECTLY SUPPORTING THE UNITED STATES SECRET SERVICE (USSS) AND THE OFFICE OF THE PRESIDENT OF THE UNITED STATES (POTUS) AND REGULARLY SCHEDULED COMMERCIAL PASSENGER AND CARGO AIRCRAFT ARRIVING INTO AND/OR DEPARTING FROM WACO RGNL (ACT) AIRPORT, TX. THESE AIRCRAFT SHALL AVOID PROHIBITED AREA 49 (P-49) UNLESS THEY RECEIVE USSS AUTHORIZATION BY CALLING 253-982-4306 OR 4678. 2. FOR OPERATIONS WITHIN THE TFR, ALL MEDICAL FLIGHT OPERATION COMPANIES SHALL COORDINATE WITH THE USSS PRIOR TO THIS NOTAM GOING END PART 1 OF 4 WIE UNTIL UFN
PART 2 OF 4 FLIGHT RESTRICTIONS CRAWFORD, TEXAS, INTO EFFECT TO AVOID POTENTIAL DELAYS. B. WITHIN THE AIRSPACE BETWEEN 10 NMR AND 30 NMR: 1. ALL AIRCRAFT ENTERING OR EXITING THE 30 NMR TFR SHALL BE ON AN ACTIVE IFR OR VFR FLIGHT PLAN WITH A DISCRETE CODE ASSIGNED BY AN AIR TRAFFIC CONTROL (ATC) FACILITY. AIRCRAFT SHALL BE SQUAWKING THE DISCRETE CODE PRIOR TO DEPARTURE AND AT ALL TIMES WHILE IN THE TFR. 2. ALL AIRCRAFT ENTERING OR EXITING THE 30 NMR TFR MUST REMAIN IN TWO-WAY RADIO COMMUNICATIONS WITH ATC. 3. ALL AIRCRAFT OPERATING WITHIN THE 10 TO 30 NMR TFR AND OPERATING AT ALTITUDES OF UP TO FL180 ARE LIMITED TO AIRCRAFT ARRIVING OR DEPARTING LOCAL AIRFIELDS AND ATC MAY AUTHORIZE TRANSIT OPERATIONS. AIRCRAFT MAY NOT LOITER. 4. FLIGHT TRAINING, PRACTICE INSTRUMENT APPROACHES, AEROBATIC FLIGHT, GLIDER OPERATIONS, PARACHUTE OPERATIONS, ULTRALIGHT, HANG END PART 2 OF 4 WIE UNTIL UFN
PART 3 OF 4 FLIGHT RESTRICTIONS CRAWFORD, TEXAS, GLIDING, BANNER TOWING OPERATIONS, AGRICULTURE/CROP DUSTING, BALLOON OPERATIONS, ANIMAL POPULATION CONTROL FLIGHT OPERATIONS, AND COMMERCIAL CARGO/CARRIER OPERATIONS THAT FAIL TO MEET OR EXCEED THE TRANSPORTATION SECURITY ADMINISTRATION S DOMESTIC SECURITY INTEGRATED PROGRAM STANDARDS, AIRCRAFT OPERATOR STANDARD SECURITY PROGRAM (AOSSP), DOMESTIC SECURITY INTEGRATION PROGRAM (DSIP), TWELVE FIVE STANDARD SECURITY PROGRAM (TFSSP), OR ALL-CARGO INTERNATIONAL SECURITY PROCEDURE (ACISP) ARE NOT AUTHORIZED. 5. ALL USSS CLEARED AIRCRAFT OPERATORS BASED IN THE AREA SHOULD NOTIFY THE USSS PRIOR TO THEIR DEPARTURE BY CALLING 253-982-4306 OR 4678. 6. ALL AIRCRAFT DEPARTING FROM PRIVATE AIRPORTS/AIRSTRIPS MUST BE ON A HEADING AWAY FROM P-49. 7. ALL MEDICAL FLIGHT OPERATION COMPANIES SHALL COORDINATE WITH THE USSS PRIOR TO THIS NOTAM GOING INTO EFFECT TO AVOID POTENTIAL DELAYS WHEN THE NOTAM IS IN EFFECT. END PART 3 OF 4 WIE UNTIL UFN PART 4 OF 4 FLIGHT RESTRICTIONS CRAWFORD, TEXAS, 8. ALL FORT HOOD U.S. ARMY FLIGHTS WILL BE PROVIDED DISCRETE BEACON CODES BY LOCAL ATC AND ALLOWED TO OPERATE NORMALLY WITHIN THE FORT HOOD AIRSPACE. 9. APPROVED MILITARY FLIGHTS WILL BE PERMITTED TO CONDUCT PRACTICE FLIGHT OPERATIONS IN THE VICINITY OF WACO RGNL AIRPORT WHILE UNDER THE DIRECTION OF ATC. CONSULT WITH LOCAL ATC FOR DETAILS. C. FLIGHT OPERATIONS ARE AUTHORIZED FOR ALL AIRCRAFT THAT OPERATE WITHIN A 4 NMR OF 310509N/0974111W OR THE GRK058007(SKYLARK FIELD AIRPORT) EXCLUDING R-6302A/B. D. IT IS RECOMMENDED THAT ALL AIRCRAFT OPERATORS CHECK NOTAMS FREQUENTLY FOR POSSIBLE REQUIRED CHANGES TO THIS TFR PRIOR TO OPERATIONS WITHIN THIS REGION. END PART 4 OF 4 WIE UNTIL UFN
Current TFRs:
