I got an O320 E2d with my rv4 project. It is in pieces but the pricey bits are yellow tagged. I have been tring to figure out if I can use a CS prop with it. I see that the acc case needs to be machined. I also have read on the forum that the e2d has an o235 front bearing. I see in the parts catalogue that the front bearing is not the same as those engines that do come set up for CS use. Is a front bearing change required? Where could I learn more about what goes with what? If I can set it up for a prop gov, the rear case would habe to be accurately machined so the gears would mesh correctly. Would anyone know where to find the appropriate drawing?
There is just so much to learn....spending more time reading than building!
