I don’t mind to be singled out if it is done with good intention and constructive criticism.
I had talked to VANS just to make sure my deviation is not of a great concern and they confirmed that as long as it is properly safety wired/cotter pinned. FWIW, my thoughts on the use of a nut plate was due to the fact that since this is not a properly torqued bolt, it has a greater chance of coming loose, hence both the bolt and nut needs to be fixed. I think it is also important to note that the safety wire ought not to go to the slotted bracket, just for the reason you have stated.
The problem with asking this type of question of one person at Van's is that no one person knows the most correct answer to every single question that can be asked (nor should they be expected to).
An actual test rig was built and tests were done to determine what configuration would be the most reliable with the multitude of variables that could be involved in an accident. The configuration specified in the plans is the result of those tests.
I do not understand your concern (and justification?) for not using the nut plate because of concern for it coming loose..... The plans specify a drill head bolt safetied with safety wire.....
