AX-O
I am converting my o-320 B2B to fuel injection and adding a cold air sump. My cylinders are the old style and only have provisions for primer ports on the bottom. I will be using the primer ports for the fuel injection. My question is, can I get manifold pressure out of anywhere else other than the cylinders? I don?t want to take the cylinder off and have it tapped for the fitting. Although I am running a fix prop I would like to have the information. Also, sometime in the future I may replace my mags. I think all those high speed ignition systems require MP.
I have a buddy that is taking his MP out of his intake plenum. He told me that when the valves opens inside the engine the pressure in the plenum is the same as the cylinders. Is that true?
