Borescope advice
rvanstory
Attached are 2 pics of my #2 cylinder exhaust valve. I think I might need to lap this valve, but wanted others opinions. It’s an IO-540. Thoughts from those more experienced than me?
It really does not look that bad to me. How was the compression? It’s so easy to accomplish the lapping in place and if you are on the fence, you should go ahead a do it. I have done every one of my exhaust valves in the 1500 hours of operating time on my engine. In all cases the issue was resolved Some of mine looked quite a bit worse than yours.
Exhaust lapping
Agree this doesn't look bad, but also: What compressions are you seeing? White lead deposits accumulating over time on the valve seat are usual, and the reasonably straight forward lapping process will get rid of the deposits and can recover some lost compression. On the other hand, for most moderate deposits and mild compression deficits, lapping is not absolutely necessary, as under operating pressures, the leakage is not significant. However, if you see exhaust valve hot spots (not apparent in your picture), then it's time to check for lack of valve rotation, and fix that first, then possibly lapping. There are some real good presentations of lapping as well as diagnosing lack of valve rotation issues on Mike Busch's site
https://resources.savvyaviation.com/resources/mikes-articles/
71 is a bit low for the time on your engine, even if it was cold. I had one that low and brought it back up to 79 after lapping the exhaust valve.
It has started to fail. "It does not look bad" just means it is not on the verge of failing. Lapping it may bring the temps back down, but it has seen over-temp already. The metal has ben stressed. Spend the money for a subscription to Savy Analysis and send them the phots plus your engine monitor data. I would trust them compleately to advise how much this should worry you. It will be $129 well spent.
I would also perform a wobble test on that valve...
didn't see this originally. It looks to me that approximately 1/4 of the circumference of the valve seating area is not making contact with the seat. Several reasons for this. Lapping is a good first attempt to addess it, but it could also be an issue with the way the seat was ground. No gaurantee that lapping will address it, as that is taking off a microscopic layer of metal and really only works if the issue is debris or VERY small imperfections. Is this the first borescope? Would be helpfull to know if this just showed up or has been around since the beginning. my first guess is that the seat was ground with the tooling slightly off parallel from the guide (not tightening the pilot stem enough).
Insert the scope through the other plug hole and try to get a look at the seat contact surface. You should notice a distinct difference in the look of the contact area where the valve is not making contact vs where it is. If you see a chunk of debris at the center causing the gap, then lapping should clean it up.
Borescope vs compression with Mike Bush
This is very timely. I just watched this presentation by Mike Bush. I, like most of us that work on our own airplanes, believed that compression was the final decider. Watch this video and learn why the FAA has done away with that requirement. Instead borescopy is now the method to determine valve health. There's a chart that shows what good valves look like and valves that are about to fail. l think your valve looks pretty sick. But watch the video and you decide.
Boroscopy
Great video. The irregularity of that valve’s surface coloring concerns me. But to be able to send images to Savvy would be worth the cost of their analysis. I also see a new toy, I mean “tool” to add to my arsenal in the shop.
