I am waiting for word from Vans Support, but I think finally I made the mistake that is going to require some expensive re-ordering... Red arrow on the attached picture is the hole I drilled #19 by accident.
Veteran builders already know this, but building when you are tired and it is late at night is just begging for disaster.
Witness the mistake I made Friday night:
There is even a note which says to be careful drilling the middle nutplate screw hole. I believe what is going to attach to this is a fairing against the fuse and I assume that is fiberglass so I am unclear fixing this is going to work other than replacing skins, doublers, and the rib below.
The way I did this by the way, for the next person is that I had all the clecos in place and the way I had them in there made this look like it was just another cluster of three holes rather than a cluster of four holes. In other words the hole that was supposed to be drilled #19 had a cleco in it. I looked at it, and drilled the top most hole of the three that were exposed which was correct for a one leg nutplate. Only problem is that it is the top most hole of the FOUR holes not the three. So as you see in the diagram I am off by one hole. I really was on a roll before this, hopefully it is fixable in some other way, but I am at a loss as to how right now.
Jeff
Jeff
