Does anyone near LZU burn auto gas? If so where can you reliably get clean no alcohol gas? Thanks
walkman Well Known Member Oct 5, 2012 #1 Does anyone near LZU burn auto gas? If so where can you reliably get clean no alcohol gas? Thanks
mannanj Well Known Member Oct 5, 2012 #2 Gas walkman said: Does anyone near LZU burn auto gas? If so where can you reliably get clean no alcohol gas? Thanks Click to expand... Check the marinas on Lake Lanier. Course at the marinas, it's going to cost about as much as avgas. Some stations on the roads into the lake may have alcohol free gas.
rvpilot Well Known Member Oct 5, 2012 #3 Check Valero stations.... The one in Monroe has recreational, no alcohol fuel. Madison (52A) is also putting a recreational fuel pump on the field.
B bkthomps Well Known Member Oct 8, 2012 #4 airnav.com has a fuel searcher that shows mogas (no alcohol) http://airnav.com/fuel/ Last edited: Oct 8, 2012
gnuse Well Known Member Oct 8, 2012 #5 Thankfully it can be found in North Georgia, here is a good link to use. http://pure-gas.org
