PilotBrent
I'm installing the wiring in finish kit section 31B and I have three questions for the experienced builders ahead of me (that might be embarrassing). Maybe I can't see the fuselage for all the aluminum.
Question 1. Roll servo Section 31B-20. Mentions installation of the black ground lead from pin #9 (step 2) in the molex connector but I can't seem to locate any mention in the plans specifically where the ring terminal is suppose to be attached. Its clearly a screw location, but where exactly?
Question 2. Similar to above for the pitch servo. I have two grounds, one black lead from the molex connector and one from the noise filter (section 44-04 figure 3). Picture below. Do both get grounded on the same screw on the seat rib (44A-04 figure 3)? Again I don't see any clear mention about grounding both of the ring terminals together.
Question 3. Most confusing. Both pitch and roll servos have no more than 7 wires coming from them into the molex connectors. But installing the finish kit, it seems the plans have 9 different leads to insert into the molex connector coming from the Skyview wiring harnesses. (eg. for pitch servo 31B-09 figure 2 has 5 wires called out, and 31B-19 figure 3 has 4 more wires to add to the same molex connector) Since the servos only have 7 wires to connect to the molex connector, what is the purpose of these 2 additional wires?
