wirejock
This thread is about all the cables going from the avionics bay to everywhere else. I made a list with conductor/size or manufacturer's designation. There's a lot. List is below
First question
I see OP-30 shows wire going up the tunnel then up the firewall tunnel and back. I've also seen wire going up the F-902 Bulkhead. What route did you take?
Second question
I have this document. Do I interpret the drawing correctly? One hole may be drilled in each bay? Potentially four holes total?
List. The ACM requires individual runs for the servos and ADAHRS so no hub.
Com,coax
Xponder,coax
ADSB,coax
Wing Tip left, 18/2 (Land/Taxi), 22/3 (Strobe/Pos)
Wing Tip right, "
Tail strobe, 22/2
Stall switch, 18/1
Sticks, ACM cable
Boost pump, 18/1 red, 18/1 Blk
Roll Servo, Dynon network cable
Pitch Servo, Dynon network cable
ADAHRS, Dynon network cable
Pitch Trim, Ray Allen cable
Roll Trim, Ray Allen cable
ELT, 22/3
First question
Second question
Com,coax
Xponder,coax
ADSB,coax
Wing Tip right, "
Tail strobe, 22/2
Stall switch, 18/1
Sticks, ACM cable
ELT, 22/3
