I'm at the point of joining the front fuselage together. Not the big join with the tailcone. There are 5 3/8" rivets on each side that go thru the aft gear brace into the skin that weren't riveted earlier (page 26-13). When did everyone rivet them?
Page 29-03 has you installing the gear brace U-01402 and tightening down the bolts. Then next page has you installing the rest of the rivets in the area, but those 5 are under the U-01402 gear brace.
When did you install those rivets? I'm thinking after fitting and clecoing the 1485 side braces, etc. I looked, but can't find when those 5 per side are explicitly called out, except too late. Probably overthinking this, but this seems to be a hole in the build order that is listed in the plans. That, or I am overlooking something, been there and done that a time or two.
