I could not find a thread on the combination of this setup. I am starting a panel upgrade and with time and cost a concern I didn't want to start completely over with and new Aerosport panel, but wanted the center console, and lower panel. It's not finished, but installed and functional.
If you look at the fuel selector you can see the modified location.
The center console is approximately 1.5" forward from intended, and I had to increase the angle of the lower panel by about 2 degrees. I am happy with the results, but plan to incorporate the stock Vans throttle mounting angle into the lower panel by moving it back about 1/8" for a smoother transition between the two. The Vans throttle mount is 1/4" wider than the Aerosport panel and centers up perfect.
Can't wait to get the new panel started.
