A/C compressor cover
50Pesos
I’d love to pics on how you solved covering the compressor. Thank in advance
L/H Baffle Intake with aero Cover for belt
The best way to mount your A/C compressor is low in the bottom cowl. You will be required to make a blister so the compressor does not touch the lower cowl.
Benefits are unobstructed cooling to the L/H side of engine.
I used a left over piece of main gear fairing to fashion an aero cover for the main A/C Drive belt. Once installed, there is no leakage from the upper plenum to the lower plenum maintaining the pressure differential.
A removable cowl baffle rubber will be installed soon on top of the cowl cheek to give a seamless transition to the baffle ramp.
This is a new installation and final baffle rubbers are not installed yet.
ABLVV85ZXhsFKN1u2KyVVFLGQ7t2T2hXSVvZ6mEzdEmLidkG4eO19RTmjAMrPkoxPz3ouR_R2FLsDazSeDOX-pjNqcVOI6A6sCC8e3PV-281QtrlvF3wn3ToPZg0nlz6uyvhnts3T-yapP-CG0BKXoYxew4HKQ=w800-h1000
ABLVV86mSlHZLf5rjhP847Nt1cZmr8sVsx4fodhC1_8Zy-O-CQP-9WphM9uhAix2KnIJdfKDYSGPSscvEy7Y6lO6Dlt2O0vYgcGH3EfTB_PEydUcTbSJzSJO9lfqjEGcrtk5PeuzW29qwFfyjyJ9v-5XCuNR2w=w800-h1000
Cowl Blister without Belt Aerocover,
ABLVV85HQ4UpMIojJQFsdgVNdLFc3gQe6UR0D1Mk4Qd6iNxs-Cg1qx-3Xl_UHEj0UGrZ73VETNcGs6UrXzGzm-srMta8PU-3YmB9G-8vQX_tcnt_mk1eD0FwjfnlJYmbltgr8wgpIrRpCHFe2SPkC1Y8mCZzig=w800-h1000
ABLVV846g3eZZBTqvves16aXNaejh8t1v884p7JgQqslp1PrTliU6nY0uMlDzotV5V-ZR54AZo8EDDkrk-YptsT4_2NBj3wxM9AHDM9uRfBsZbv7M0vEgc-W5x9kdI1fW3xJBEzIVJKxgooIvnjGyrVkYua3zg=w800-h1000
ABLVV85pgOtXk1V2IyFkatcd3JyFUdvp12G9vvOF43hh-QXmQfCS3BDYPTMQHI4KMLnFo_cqKys1v6I0nzPgU0g_Ob8ALorx9LO5ubYiNADTz2T-aySRSAHUMaBTP72oPkcoM8cjI7pGNxrd3OvtCFIct8AFcw=w800-h1000
