NeilMcLeod
Active Member
Looking for a reference on how to wire the Garmin 296 so it talks to the 327 and SL40
If you want to gamble it might be the same harness as your 12v power wire if you cut the adapter plug off.
On the back of my 296, there's the powerwire which is going into the "sigarette outlet" for charging, the antenna connector, the 5-pin connector which is for updating the software... and that's it....
Where's the 9-pin connector mentioned in the diagram...??
I don't know this first-hand, but I was told by a usually reliable Garmin guy that if you cut the cigar lighter end off, you won't find anything but the power wires.....might not be a good gamble! we bought the accessory cable when we wired up Louise's plane last year.
Paul
