Bsquared
Sorry if this has been asked before....I did a search and did not see any previous posts that were related. When you do a compression test at the annual condition inspection, or whenever you remove an auto plug for any reason, do you reinstall the plug using the non replaceable gasket. I am not referring to the copper gasket under the adapter....that should always be replaced. There are two possible scenarios.....you remove the plug using a 14MM socket and the adapter either stays put or else it comes out with the plug. P mag tech support recommends using new auto plugs whenever they are removed but what are people really doing?
