Rotax just released their own Lithium-ion battery to go with their engine - underneath it is just EarthX battery in Rotax clothing :)
Obviously thy do trust underlying technology ….
With all the charging system/ regulator problem the RV12 has had not sure if I’d be onboard with that!
And Rotax clearly put the operator in the position of determining “certification”.
“The battery is not a part of the Engine Type Design. Lithium-ion batteries
part no. 966260 and 966265 have been tested and released by BRP-
Rotax, but are not certified. The correct function in conjunction with the
entire electrical system is the responsibility of the aircraft manufacturer.
The certification of the battery is the responsibility of the aircraft
manufacturer and must be carried out jointly with the aircraft.”
Examples that are irrelevant.
why are they irrelevant? Possibly because they perfectly illustrate the point that each technology has its own level of perceived risk?
You may not like the new technologies but that doesn’t make them bad…
For example, if there is a regulator failure, as mentioned on this thread, and the voltage raises beyond a cetain threshold which I think is 16.2 volts for more than 2 seconds, the Battery that is currently on-line will shut down. In that case, one solution would be to turn off the alternator and then run from the second battery while finding the closest place to land. (note, I also will have a secondary alternator with a different regulator set to a lower voltage)
The BMS will not "shut down" the battery in the sense that you are thinking in the event of high voltage. It will not isolate the battery - it only stop incoming current from going to the battery. If you stop the high voltage event, you can still draw power FROM the battery, you just can't put any more INTO the battery until the BMS resets itself after the high voltage event.
Exactly correct, the battery protects itself - but that is not the point.
If the battery stops incoming current during an over voltage event, the voltage spike still happens but now there is no battery to cap the voltage excursion it as would be the case for a dumb lead acid battery.
As I said, do not assume your alternator over voltage protection will save your very pricey avionics. Test the system to see at what voltage it trips the alternator off line. A good reference is section 6 of “The Aero-Electric Connection”.
I also suggest a system design that has a common POH immediate action for any electrical fault. Beat this into your head as a bad over voltage excursion can happen very fast. In my plane that action is open both master solenoids, then evaluate. My panel gets power via separate feeds from each battery - the result is the panel is still up for a 2-3 hours but the alternators (and associated fat wires) are isolated from the battery.
As been discussed, the EarthEx has a lot of capability that makes it attractive for our planes. As the builder (and system designer) understands it’s limitations as well as it’s advantages.
One last comment. Please carefully document your wiring, connections and equipment integration. You will make life much easier for those who get your plane when you are done with it.
I’ve been using the earthx batteries for many years on both mine and our customers airplanes. Their support has been stellar, even when the battery failure was caused by the customer. There’s a post in the forum somewhere where I compared the odyssey battery to the earthx and the results were amazing, especially the difference in cranking speeds and reserve capacity. I use the 1200 in the RV-10.
As has been mentioned, they do need to be cooled if placed on the firewall.
There are lots of potential failure scenarios for both types of batteries. Most of them that I have seen come down to bad wiring or poor alternators.
One wiring bad practice that I consistently see is routing the field wire parallel and cable tied to the main B lead from the alternator. If the field wire ever chafes through the big wire, the alternator voltage will spike very high and very fast. The only way to stop it is to pull the alternator CB, as your field switch is no longer effective, due to the downstream short. Yes, it has happened. You might check yours.
Vic
Carl and Walt both have very valid points - you want to have a WORKING (that means test it!) over-voltage device to drop the alternator field current offline, and you want to make sure a short like Walt refers to can't happen. If the field wire is energized via a short to the B-lead in the FWF area, the alternator will run away and there is no way to control it unless you have a B-lead breaker (and not many folks have one of those) to isolate that before it gets onto your power buss. The commonly seen ANL fuses will burn away if this occurs feeding a lead-acid battery, as that battery will accept the overvoltage and boil its life away while pulling enough amps from the alternator to eventually blow the ANL. With an EarthX battery and the BMS taking the battery off the charge circuit, that same runaway alternator will spike in voltage, but with no place to put it, not nearly enough amps will flow to worry that ANL fuse, so it will stay connected. That could result in letting the magic smoke out of your high-dollar boxes.
In my case with a stone age basic super simple systems I prefer, practically anyone who knows anything about electrons could figure it out.
Multiple relays-no, multiple bat busses/bus switches-no, diodes everywhere-nope.
Some fuses and CB's tied to a single bus, easy-peasy, simple, reliable.
Except for the constant fear of exploding lead acid batteries of course, o_O
Vic
Not sure I agree with this, bundling wires is a pretty standard thing, the real problem is the installation, not the fact that it's bundled together.
… If the field wire is energized via a short to the B-lead in the FWF area, the alternator will run away and there is no way to control it unless you have a B-lead breaker (and not many folks have one of those) to isolate that before it gets onto your power buss. The commonly seen ANL fuses will burn away if this occurs feeding a lead-acid battery, as that battery will accept the overvoltage and boil its life away while pulling enough amps from the alternator to eventually blow the ANL…
I have a different understanding:
  • Let there be a 60A alternator and 60A ANL current limiter.
  • Assume the 60A alternator can exceed its rating by 20% so 72A. I believe this is conservatively high in this context. An alternator cannot exceed its rating by a great deal fundamentally because the materials in its magnetic circuit saturate. Ref Balmar brand curves for example.
  • A Bussmann ANL current limiter placarded at 60A will carry something over 100A indefinitely, maybe 120A, eyeballing the ”Time-current curves – average melt”.
BTW I’m aware of an RV that purportedly had the B and field wires short together:
  • Pilot didn’t/couldn't pull B lead CB, all electronics destroyed.
  • Sorry I don’t know the CB rating or battery chemistry.
  • My point is the pilot didn’t/couldn’t to pull the B lead CB. Walt points out in the next post that “Most 60 amp breakers cannot be pulled!”… I didn’t know that, thanks!… I’m using a Littelfuse 100A MIDI fuse.
  • Obviously best to craft the installation so shorting of B lead to field wire is impossible. And to periodically test OV protection.
Or the constant fear of everything else…
That’s ok, though, everyone has there own level of risk aversion…
I had an issue in the Arizona heat of summer one year with my EarthX in an RV-7A. Mine is also on my firewall inside the engine bay and it overheated once after I had landed in Scottsdale in Summer. The battery has an internal safety mechanism that shuts it down if it gets too hot so it won't destroy all your other systems. However, once that internal EarthX batter protection mechanism trips, you can't reset it, you need to buy a new battery. I had to land NORDO but NONE of my other systems (alternator, fuses, wiring, etc) were affected. It was a $350 mistake not to open the oil door and allow the internal compartment to cool once I had landed in that hot environment. Now I open the oil door and let the engine bay cool off before walking away from the plane if I land in a hot environment. It has been NO PROBLEM since then. Usually, five minutes or so is fine. Hope that helps!
I'm a little confused. You had to land NORDO because Earth X shut down the battery in flight or you over-heated the battery because you did not open the oil door to cool it?
Per Earth-X an overheated battery in flight (As long as the temp is below 200 F which then starts to affect the electronics) will not shut the BMS down. I have 2 batteries FWF one high (plans) and one low and if I set on the ground for an excessive amount of time, I get an over-temp alarm in the battery that's installed low. (Florida summers) I am trying to address the issue with blast tubes. I have 2 thermocouples mounted in the 2 batteries and the lower one see temps in the 150 F range if I need to wait to depart, upper one never exceeds 120 F. Nothing but good things to say after 6 years of usage. I have been using the same chemistry for close to 20 years in various airframes with very good results.
This comes up all the time. B&C even warns about it. I just have a hard time believing two wires with modern insulation routed in parallel chafed against each other to the point the made a sufficient connection to provide the full alternator field current. Ill give $50.00 to VAF if someone provides a picture of such a short on a RV alternator.
Yes, I didn't open the oil door to cool it and it shut down as soon as I took off from Deer Valley, AZ that day immediately after refueling. I had NO IDEA about the cooling issue at that time. I have had ZERO issues since. It's a GREAT solution, even though I have mine on the Firewall in the engine compartment. All I do is make sure to open the oil door for a few minutes after landing and I'm fine.
Not quite the same but I worked on a lancair that had a B lead chafe on an exhaust pipe. Welded the cable to the exhaust; pretty impressive.
I’m always amazed on this forum when you try to share something someone always wants to argue about it. I am aware of 2 instances where this has happened and have seen others that have come close. Many of you forget that not everyone is trained in best wiring practices. I have seen so many RVs wired with automotive wiring and automotive connectors that are barely crimped that I have last count. I’m glad you want $50 for someone to show you this. I’ve looked at over 2000 RVs and am trying to share observations so others can learn. How many have you looked at???
B&C is aware of others, as I have spoken to them about it.
Vic
Vic
I Don’t believe these two wires making contact with each other is a failure mode that requires mitigation. sure It’s possible but If this has happened surely someone took a picture.
How many other wires in bundles do we have in our aircraft? I have plenty of 22ga wire bundles for my avionics. By following good standard aircraft practices, and using aircraft quality materials this should not be a problem.
I’ve seen the aftermath of a completely toasted panel and wiring. My comments are not directed at those using nice tefzel wire and good wiring practices. Why you continue to argue is beyond me. Do you ever stop and realize how many aircraft are now on their second, third, or fourth owners, some of which are 30-40 year old aircraft, wired with automotive wire and connectors??? Picture automotive vinyl coated wire in a wire bundle, now wrapped tightly with wire ties and adel clamps that are just a little too tight. This bundle now goes right underneath the cylinders, where it gets hot. Ever hear of cold flow on wire insulation. Look it up. Eventually that wire that is wrapped too tightly will rub right through the insulation just from cold flow. And now we are adding the heat component.
I share things in the hopes that those here that DIDN‘T wire their airplane might get the idea that they should go look at theirs, and perhaps save themselves some grief down the line. I’m trying to help those who don’t know they need it. Those of you who are wiring with current best practices, aircraft grade wiring and connectors are just giving a false sense of security to those who didn’t and may not even know what’s in their airplane by arguing.
I’m not here to look like I’m smarter than anyone else. There are certainly many people on this forum that are much smarter. I’m just sharing what I’ve seen.
Vic
Vic
Vic, what you don't have in smarts, you make up for in good looks! :) Love your videos - I learn a lot from every one. Not to mention the books - great stuff!
The reason I keep arguing is I don’t believe running the field and B lead together is a bad wiring practice. To get the fault you described the two wires have to make contact with each other and not ground. I tried to make an 18 and 8 gauge wire touch by smashing them in a vise. The wires make contact with the vise first and took a crazy amount of force to do that. If the bad wiring practice you are referring to is using automotive wire say so.
What does smashing them in a vise show? Put them together and let vibration and relative motion have a chance to work on them…
Regardless of what I think this apparently can and has happened. I followed the B&C installation instructions for the case mount L-40 alternator and LR3D regulator to the letter and there was no mention of this. B&C thought the probability of it occurring was 1 in 10,000 and included a note to separate them in the instructions in later models like the LX-60. I don’t think I will reroute it as is it is possible to inspect the wire easily.
MIKE
Vic
I never thought of the field wire potentially shorting to the B lead. Mine are routed that way. I was careful to make sure the wires do not chafe on anything and I used Tefzel insulated wire. However, I will separate the two wires the next time I have the cowl off. Once again...thanks for the tip Vic.
I think Vic's point is valid/has merit if the aircraft is wired with automotive/radio shack or some other substandard wire and is not properly secured.
If Tefzel wire exhibited this phenomenon when bundled, we would have to ground virtually every aircraft made in the last 50 yrs.
Please Ref the 'bible' AC 43-13 for more info on wire materials and installation.
I will continue to route field and B lead wires together when it makes sense to do so.
I mean really, what's the problem with at least being aware that if the field wire and B lead get together it's gonna bring some excitement into your life. Yeah, maybe it will never happen, but then again, maybe it will; probably not tomorrow but maybe 40 years from now when I'm 99 and my as of yet imaginary grandkid is flying this thing.
In my case it was more convenient to run them together. Both were tefzel wire, but I also sleeved the field wire in fiberglass anti chafe because its what I had on hand, then I used standoffs at the wire ties to keep them about 1/4" apart. Cheap insurance, cost almost nothing, and added another 20 minutes to my day.
As for the OP's original question. I don't have a service history, but in an effort to compensate for my heavy engine, I installed a compact EarthX ETX680C on the firewall. When I saw how tiny it was, I had a brief panic moment that even though EarthX said it was right for the job, maybe I'd made a mistake. It's about the same side as the battery for my electric weed eater and only weighs 4 lbs. It just didn't seem possible that it could have that many electrons crammed into such a tiny box.
I needn't have worried, it swings my IO390 like a MOFO.
