KJBSouth
Our 3D printer is a Wanhao Duplicator 6 purchased at a 3D printer store north of Tampa. After the magnetic oil door latch, I turned my attention to other 3D printable parts. As Experimental Aircraft Association members we have access to no-charge personal use copies of SolidWorks Design Software.
The upper ignition wires for our Lycoming engine pass through aluminum sheet metal baffles and must be protected from chafing. A well known aviation supply store sells nylon plastic wire protectors for $21.95 each, and one set is needed for each side of the engine. Having time to spare before returning to Michigan I designed and printed these.
The two halves are identical and interlock around the ignition wires. They install on a one inch diameter hole in the rear baffle plate.
The wire guides are made with ABS plastic that has a glass transition temperature (softening point) higher than nylon.
It's a few cents of plastic. Don't ask me how much the printer cost.
