Dan Langhout
OK, I know there are some lighting experts out there who can give me an informed opinion on this.
I am trying to get a ballpark measurement of intensity (in candela) of an LED Position/Strobe light. Based on my understanding of the photometric units of measure (which is tenuous at best) it would seem that you would measure the illuminance (lux or foot-candles) with a light meter and then multiply by the square of the distance from the sensor to the light (meters^2 or ft^2). to get the intensity value of the source (candela)?
Given that, here is a photo of my admittedly crude measuring set up:
and the light meter I'm using:
Note that the distance between the light meter sensor and the light is 1 foot, therefore my measurements in foot-candles should also equal the candela value (1^2=1) - right?
I take the measurements in the dark even though the meter has a relative setting to null out ambient light. I use the normal setting to measure the position light and the "peak" function to measure the strobe.
OK - Please - tell me what, if anything, is wrong with my assumptions or measuring setup. I'm not getting results even close to what I expect.
