fstringham7a
Here are a couple of pictures of the start of at least a month of painting my RV7A with the Stewart System Paint......www.stewartsystems.aero
Todays venture was to paint the custom fabricated FG ram air induction nostril and the two custom FG cowl hinge pin covers with Ekofill UV primer/filler. The process calls for first using compressed air source to blow off all the sanding dust and then clean the part with EkoClean/rinse with water/let dry. Then the process calls for using a foam brush to put on the first two coats of the primer filler.......Then using a gun with at least a 1.5 tip to spray two cross coats (total of four coats) over the two foam coats. On the cowl I will spray all six coats. Using the foam brush does creat surface bubbles that must be stroked out. The uv primer/filler must go on dull in shine or one is using to much material. Once dry the parts will be dry sanded with 320 open coat paper in preparation for application of the Stewart System Primer/Sealer White.The UV Primer/Filler is only used on the FG parts.
Tomorrow the cowl will get the above treatment.
Frank @ 1L8 ...RV7A... painting
