Old 01-29-2019, 07:53 AM
lr172 lr172 is offline
Default Flap Fitting
I foolishly forgot to install the flaps for fitting when I did my initial wing fitting and cover panel fitting. I figured that I would do any flap trimming after final wing mounting at the airport. However, the fuselage will be painted by that time. I am assuming that I will be able to put some tape over the paint and have no problems with scratches. Is there anything I missing here? Any "gotcha's" that will prevent me from pulling this off? I can't visualize any, but I haven't done this on a 10 before.
Currently seeing sub-0 weather, so this won't be happening on my driveway again any time soon.
N64LR
RV-10 in progress
Old 01-29-2019, 08:47 AM
Electrogunner Electrogunner is offline
Default Flaps
Should not be a problem. Swing the flap up and trim until it clears the fuselage.
RV10 N620RV
IO540 C4B5
Whirlwind 375HRT
Garmin G900X
First Flight 2/14/2019
Old 01-29-2019, 10:40 AM
Thanks! That's what I thought.
N64LR
RV-10 in progress
Old 01-29-2019, 12:02 PM
Bill Boyd's Avatar
Default Don't make my mistake
See this fancy drag-reducing closeout of the outboard end rib on my right flap? I did them on the inboard side as well. Before trimming the flap to fit the fuse. Without realizing the inboard end isn't exposed to the slipstream when the flaps are up.
It's all getting ground away to make room for flap fitment to fuselage.
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 01-29-2019, 12:10 PM
Looks pretty. Too bad it had to go. Your post earlier got me thinking about my error.
N64LR
RV-10 in progress
Old 01-30-2019, 05:00 AM
Bill Boyd's Avatar
Default After 2 nights in the shop, sanding the inboard flap ends
and still not done - I'd say you have some work still ahead. (I'm also wondering how you rigged aileron and wingtip neutral without a full-up flap to work from, but that's another story.)
Plans call for 1/16" minimum gap between flap and fuselage. Now that I have flaps snuggly fitted, I will scribe a 1/16" line and remove flaps for final grinding / filing to that clearance (better access than lying under the belly). To get to that first fully-seated point without scratching your fuselage paint is going to require the greatest of care, I think. Work slowly, or you will scuff something.
Bill Boyd
Old 01-30-2019, 08:15 AM
Default +1
I was wondering the same ting about the aileron/wingtip rigging without the flaps...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 01-30-2019, 10:23 AM
I did all rigging on the wing stand, before my wing attach work. Flaps were installed and forced all the way up against the spar; Gravity holds them there. Use a clamp to hold aileron in alignment with flap. Then adjust linkage to get the bell crank and torque tubes at their neutral positions. Then drill wingtips while held in alignment with aileron. Rigging to the control sticks and flap linkage rigging will be done at the airport, when wings are final installed. However, all parts get painted while still in my garage.
I couldn't afford to leave my plane on the driveway for several days with the wings on and my plan calls for paint before moving to the airport. Only had enough time for the basics of rear spar drilling and working with the wing root covers. I agree it would have been wise to put the flaps on and deal with trimming and flap linkage while at that phase, but I simply forgot to do it. This 6 was easier, as I could have one wing on while still in the garage and that gave me more time.
N64LR
RV-10 in progress
Old 01-30-2019, 10:30 AM
Bill Boyd's Avatar
Default Puzzled...
Final trimming of the flaps - - full-up against the rear spar leaves the trailing edge about 3/16" high vs the side/belly corner of the fuselage. With the care that Van's has put into the fit of the RV-10 components, I find myself second-guessing whether the flap reflex position isn't supposed to be with the underside of the flap perfectly aligned with the belly of the aircraft.
But I guess that's my OCD assuming that Van has OCD, too.
Bill Boyd
Old 01-30-2019, 10:38 AM
Bill Boyd's Avatar
Default Fasteagle, your inbox is full
Hey, Frank -
My method was to fill the recesses with high density expanding foam from a spray can - Loctite brand from the local hardware. Let it expand for 2 days in a warm shop, then trim and sand flush, fill surface voids with micro slurry (epoxy/microballoons) and then wrap with lightweight crowsfoot cloth/epoxy resin, sand and fill as required. Best way to make the glass hug the outside corner geometry was to leave plastic food wrap over the glass ply while it set - this can be held down tightly with masking tape and comes off easily later.
Lots of work for what you get. There are other methods out there - balsa wood, phenolic plugs covered with glass, etc. Search around. Good luck!
And yes, I did all the control surfaces and tips this way.
Bill Boyd
