Old 04-02-2017, 03:29 PM
Mark Jackson Mark Jackson is offline
Default Attaching RV-8 leading edges
I started trying to rivet the completed leading edges to the wing spar. Complete debacle. I used an offset head on the rivet gun (see pic). Inside, held the bucking bar against the rivet as per the pic below. The first set were okay not great but on the second set where I really had to reach in, they were all horrible. Drilled out all five. I have searched the threads and there really isn't very much on this.
Using AN470D4-5 as per the plans. Same bucking bar and rivet gun as always.
Is there some secret trick to this I don't know.
Rivet gun position:
Bucking bar position:
Result:
Mark Jackson
Houston, TX
RV-8 in progress/Mooney in the hangar.
Old 04-02-2017, 03:39 PM
wirejock's Avatar
wirejock wirejock is offline
Default Secret
I don't know any secret but that's exactly why I called Vans and asked about pulled rivets. I didn't want to cause damage. LP4-3 and LP4-4 was the recommendation.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 04-02-2017, 04:13 PM
sapeloson's Avatar
sapeloson sapeloson is offline
Default Same!
Had the same issues....... Same solution......
RV-8
Empennage - 95%
Wings - 95%
Fuse - 95%
Finish Kit - 95%
FWF, Wiring and Paint in progress
Garmin IFR by Stein
Lycoming IO-360 (180HP)
MT 3 Blade CS
N84TH / Registered and GA sales tax paid! $@&!;:?)(!
N3159F C-182 @ KJES
Old 04-02-2017, 04:24 PM
RV74ME RV74ME is offline
Default OR, you can try this on your second wing
This won't help you on your first wing, but this is what I did on my second wing:
http://www.vansairforce.com/communit...d.php?t=146965
Steve T.
N922WT (reserved)
KAUO (Auburn, AL)
RV-7 slow build
Tail kit COMPLETE
Wing kit COMPLETE
Fuselage kit IN PROGRESS
Old 04-02-2017, 04:25 PM
Carl Froehlich's Avatar
I suggest wrong rivet gun, wrong rivet set, and wrong bucking bar.
Try a 2X gun and a long but straight set - at around 45 PSIG. You want a palm type bucking bar that you can "feel" when properly positioned on the rivet.
Don't forget to add the 2 or 3 layers of masking tape to the rivet set. Replace the tape after 3-4 rivets.
Old 04-02-2017, 05:19 PM
ILikePike ILikePike is offline
I did my first wing vertical on the jig like your pictures. I had trouble getting these rivets set. The second wing I did horizontal with the same rivet gun, set, and bucking bar. For some reason working horizontally I was able to drive them with ease compared to the cursing required to drive them vertically. I hope this helps.
Jeff Green
2016 RV-8 #82985
1968 E33C Aerobatic Bonanza
Pleased to donate Dec 2017
Old 04-02-2017, 07:54 PM
Wunderon's Avatar
Wunderon Wunderon is offline
LP4-3 and LP4-4
Dave Grimmer
RV8 firewall forward
EAA 84
paid 2018
Old 04-02-2017, 08:03 PM
Okay. I took apart the air hose, inserted all the regulators I use for HVLP painting so I was getting exactly 40 psi at the rivet gun.
Then I used the angled rivet driver:
Much much better results. Not perfect but acceptable.
I am going to call Van's tomorrow to get the specs for blind rivets for two of the ribs that would require completely blind bucking.
Mark Jackson
Houston, TX
Old 04-03-2017, 01:51 PM
StuBob StuBob is offline
RE: Blind rivets
What rivet puller will fit in there? The one I have is too thick and, with main ribs in place, won't put the heads down flat.
Stu F.
Indianapolis (KMQJ)
Old 04-03-2017, 02:50 PM
jibby212 jibby212 is offline
I read somewhere that it was possible to shoot all the rivets from the front side of the spar so I tried it and succeeded. I had to use a remote regulator and on occasion insert the gun and the the air hose from a different hole but I think it was easier than shooting them from the back side so close to the aft ribs. My arms are not that big and if they were any bigger it would have been impossible. It seems that this area could have had some minor design changes to make everything a lot easier, for one, facing the outboard and inboard end rib flanges the other way so that they could be put on last.
