Old 10-24-2018, 07:37 PM
Girraf Girraf is offline
I was planning to get some sharkbite conduit from home depot to house the wiring for the wing tip accessories. I need more time to consider the goodies that might be installed. I'm leaning toward and IFR capable aircraft so a heated pitot would certainly be a requirement. Auto pilot is also strongly desired. I'm less concerned about those items due to their size. I mainly wanted to make sure I got all of the big items (the ones that would cost a small fortune to ship individually) included in the first order.
RV-7:
Empennage complete!
Wings in progress
Old 10-26-2018, 04:49 PM
amaris amaris is offline
If you're thinking of ordering a QB fuselage, tell them now. Otherwise they'll ship you the full kit and then you'll have to ship back the center section. From my area, that was $45 via UPS.
On my end, I damaged 1 tank end rib and inner rib, and 1 wing rib. The wing rib could have been avoided had I drilled the conduit hole before assembly.
I'm holding off on servo mounting brackets as it's still very accessible while the wing is off, oh and I don't know which auto pilot I'll be using!
I also ordered extra materials to make a fuel return line on both and I ordered additional MK-319-BS blind rivets. There were a couple spots I couldn't get a rivet in, including the service bulletin for the aileron mount area.
Allen Maris - 2019 Dues paid
7A - 544RV In Progress
Santa Ynez, CA
