Old 05-08-2013, 05:55 AM
JRo JRo is offline
Default RV-12 back window sealant
I'm looking for a recommendation on sealant for the RV-12 back window. The large concern seems to be fuel seepage, but I'm concerned, as well, with appearance. This sealant can obviously be seen through the Lexan, and all fuel sealants I've encountered are black. My RV is white, so hoping for a product that might blend better.
Also, looking for hints on tightening the rear window hardware which will never cause crazing or cracking around the holes in Lexan.
JRo
Old 05-08-2013, 01:26 PM
f1rocket's Avatar
f1rocket f1rocket is offline
Can't help you on the sealant. I've never found it necessary on any of my previous airplanes.
The most surefire way to avoid cracking involves a couple of steps during construction. First, always use a drill bit for plexiglass and go slow. Second, countersink with sufficient depth to ensure the skin will fully nestle down in the countersink without touching the plexi. Then third, overdrill the hole size to allow for a short piece of rubber tubing to fit over the screw shaft as it passes through the plexi. This seems to work for me and all my previous projects.
Randy Pflanzer
Martinsville, IN (II87)
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 05-08-2013, 02:36 PM
tadsargent's Avatar
tadsargent tadsargent is offline
Default window sealant
I used Lexel on my 7.
http://www.123ponds.com/adh-5.html?g...FStyQgodYVsAmA
Tad Stripes Sargent
TeamAeroDynamix.com
Flight Lead
ICAS Pilot
GRT HXr Glass
TITAN POWERED IO-370
Hartzell's advanced composite propeller
Old 05-08-2013, 02:54 PM
txaviator's Avatar
txaviator txaviator is offline
Originally Posted by tadsargent View Post
I saw some of this Lexel today, at my local Ace Hardware store.
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
Old 05-08-2013, 04:01 PM
skydiverlv skydiverlv is offline
According to manufacturer, gasoline will dissolve the polymers in Lexel. Not a wise choice for the 12
Larry Vandegrift
ULPower 260is, dual ECUs, dual 30 amp alternators
Old 05-08-2013, 09:14 PM
tboyett tboyett is offline
Default Maybe a bit of a stretch...
Anybody heard of or used this stuff?
http://www.eclecticproducts.com/sealall.htm
RV-12 E-AB N79AM completed
www.rv-12.blogspot.com
2016-17 VAF donation gladly made
Old 05-08-2013, 10:30 PM
That fast set time (2 - 3 min) would worry me. It seems it would be hard to work with.
I've had my RV flying a little over a year and haven't had any of the fuel spillage issues. My painter used a thin bead of what appears to be grey RTV where the plex and skin meet. There is nothing applied between skin and plex overlap area. A lot of guys here on the forum think eventually I will have problems, but so far so good.
If it ever needs replacement I intend to buy a sheet of Lexan at Home Depot and use the old window as a template to cut another one.
Old 05-09-2013, 08:13 AM
Wouldn't be hard to do but the Home Depot Lexan will be even more vulnerable to damage than what is supplied in the kit. The kit supplied window has a protective surface coating on it that common Lexan sheets don't have.
Scott McDaniels
Hubbard, Oregon
Old 05-09-2013, 11:33 AM
Scott, I never said it would work, just that I'll try it! :-)
Old 05-09-2013, 12:55 PM
And I never said it wouldn't.
Just letting the masses know that the RV-12 rear window is not made out of the same material you would buy at Home Depot. It is actually a material used extensively by NASCAR.
Scott McDaniels
Hubbard, Oregon
