Heavy right wing
Dave:
I had the same problem. Regarding rigging and the comment by vette-guy, in reality, both flaperons droop when the stick is in the neutral position. They just have you neutralize the left and set the right to 1/4 inch because it is much easier to do that than try and measure 1/8 inch droop on both sides.
You either squeeze the light wing and/or blunt the heavy one. I had a heavy right wing and the problem persisted, even after extensive squeezing of the left flaperon. In fact, we got to a point where we did not want to squeeze the trailing edge any more. We blunted the right flaperon a bit but were still unable to completely resolve the heaviness. At this point, I contacted Van's and they just suggested adding a trim wedge to one flaperon (which I did on the bottom of the left one). I hated to have to do this but the squeezing, if done too much, can become quite noticeable. The trim wedge largely resolved the problem although with full flap extension and slow speeds, I do get a bit of left wing heaviness now. However, it is basically good at cruise.
Given that everything is pre-punched and built without jigs, I still remain a bit puzzled as to why some seem to have little trouble with this and others like myself have bigger problems. Seems like having a ball out to the right and needing a rudder trim tab is pretty common and probably expected to some extent given the p factor. However, the wing heaviness seems to vary considerably between builders.
Jeff
