Old 06-11-2018, 10:12 AM
iamtheari iamtheari is offline
Default Page 26-14 step 3 - tips on riveting F-01484 center bottom skin?
I have my seat ribs clecoed to the center bottom skin. It's an exciting moment. But before I try to rivet them together, I am wondering if anyone has any tips on techniques that do or do not work. It's an awkward piece and obviously an important one.
Old 06-11-2018, 10:18 AM
Aluminum Aluminum is offline
Don't try to do it alone! It's easy with a helper.
What worked for me is building up the fuselage from the firewall back on a rotisserie.
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
2018 dues worth every penny
Old 06-11-2018, 10:30 AM
I'm waiting for my helper to come back to finish up the top skins on the tailcone, so I will just work on other sections until he finds time to come over. There is always something to work on, even if it's usually deburring and priming.
Old 06-11-2018, 11:20 AM
n982sx n982sx is offline
All of those rivets can be easily back riveted by yourself. I did it that way.
A couple of things to note.
I used a 12" offset back rivet set in my 3x gun for these but you can use a straight set as well by pushing the rib aside a bit.
I have a long back rivet plate, but if there is any curve to a section you are back riveting, just do a few at a time. Keep adjusting the assembly so that the rivets you are doing are kept square to the plate. Much easier and quicker than it may sound.
It is surprising how much can be done by yourself with back riveting. In some cases even easier than working with a bucking buddy on an awkward piece like the fuselage bottom skin. I did the entire tail cone easily by myself, back riveting all the areas I could not reach with both hands.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 06-11-2018, 12:10 PM
I was not happy with my backriveting work on the AD4 rivets from the aft gear brace to the center bottom skin. So I'm probably a little gun-shy about backriveting the ribs to it, but I suppose if I go slow it's not such a bad deal. I'll still hope my buddy can come help, though. Just a second set of eyes can be helpful on some of this stuff.
Old 06-11-2018, 01:34 PM
Not knowing what your back riveting issues were with the AD4's, I would just note that the rib rivets are all, or mostly all (I don't remember), AD3's. They are much easier to deal with and should be in your ballpark of experience as back riveting AD3's is called out in the plans in several areas on the airplane.
It's a good technique to get comfortable with, but I don't want to talk you into something that you're not comfortable with now.
Bob Meyers
Old 06-11-2018, 02:26 PM
The ribs are all AD3's, and of course I've got experience with those from the rudder, elevators, and several other places. The AD4's just seemed not to want to behave for some reason, as several ended up with their manufactured heads sitting proud of the skin. I think that, as long as I take my time, I should be okay to backrivet the ribs. But I wanted to post and ask for tips in case there are better techniques or just tricks to it to get a good result when you have the rib upper flange in the way and some tight alignments (a few rivets will take a little tapping to sit flush into the skin before I set them).
Old 06-11-2018, 08:24 PM
Allan Stern Allan Stern is offline
Default Back riveting
Have you tried using riveting tape? It helps keep rivets in holes because if you get some heads sitting proud then the heads were not flush on the back rivet plate.
Old 06-12-2018, 08:13 AM
I always use rivet tape, whether backriveting or not. I love that stuff. But tape won't hold a rivet in place if it's not sitting flat on the backrivet plate and you hit it with a rivet gun.
Also, word to the wise, if you have one rivet sitting proud, it will prop the rest of them off of the backrivet plate. I never had this happen before, so I didn't think to check in between rivets. I'm sure that I just screwed one up and it caused the rest of the issues.
I wonder if a backrivet set with a stronger spring would have avoided this. I certainly applied plenty of pressure before pulling the trigger.
Anyhow, the results aren't perfect but perfect is the enemy of good enough, and the results are good enough to build on. Just need to cowboy up and move forward with the rib and bulkhead riveting.
