Hi All,
I'm currently routing my flex fuel lines out to the side skin area and looking at where I should drill a 2nd hole in the side skins.
I have a standard setup where the brake lines are in the middle, supply line forward, and return line in the aft as they go through the systems bracket under the seats.
Tom had advised to go as straight as possible to line up with where they go through the systems brackets, but the gear weldment is partially in the way. The other factor is that I placed my return fuel bung on my tank just forward of the vent and not inline with the supply.
So what I was thinking is one of two things.
1) Drill a hole forward of the hole of the aileron control connection hole sort of vertically inline with the stock fuel line hole and route the supply through it, and the return through the stock hole.
Or
2) Drill a hole aft of the aileron control connection hole and higher than the stock fuel line hole.
I've roughly marked the 2 proposed locations in the picture below:
https://photos.app.goo.gl/hhZDxqRoxvqdqsnF7
Also a Picture of my fuel return location on the tank for reference.
https://photos.app.goo.gl/cF4iNrE9Hi7k94g1A
Wanted to get others take on what the best option might be or things I might not have considered before I start drilling holes.
Thanks!
Or
Thanks!
