N941WR
Legacy Member
Today Mazda announced it was discontinuing production of the rotary engine.
Major bummer on many levels.
the rotary design is notorious for its low fuel economy and high oil consumption
Oh, and from the article:
"the rotary design is notorious for its low fuel economy and high oil consumption"It's designed to burn oil. That's like saying "wheels are notorious for rolling".
Um, no...
Wheels are designed for the purpose of rolling. Engines are designed for the purpose of converting chemical energy into mechanical energy.
Rotary engines having high oil consumption is an undesirable consequence of a design compromise. They're designed in such a way that will burn oil, but they're not designed for the purpose of burning oil. There is a difference.
So that quote would be more analogous to saying something like "Brand A tires are notorious for high tread wear".
Anywho.
The Mazda Wankel rotary engine uses an engine driven pump to meter oil directly into the intake system, for the purpose of lubricating the combustion chamber seals.
Actually, the correct quote would be: "V-8 engines are notorious for burning gasoline"
Again, not quite. More like "Engine A is notorious for burning more gasoline than engine B to produce the same power".
You must be an engineer
Really, does it show?
From a user standpoint, high oil consumption, even if by design, is a negative. An undesirable characteristic. And it is fair to point it out as such when comparing the trade-offs between different types of engines.
So, are you criticizing the Lycoming or the Rotary with this comment? The typical two rotor uses about a quart every 1500 miles of street driving. This equates to about 30 hours per quart. Most Lycomings would be jealous.
I curious from the RX8 owners out there, how much oil does a Genisis burn?
