David-aviator
Greetings,
The Gary Newsted radiator box plate installation was completed late yesterday and with the temp at 95F this afternoon, I tested it.
For the first time I made it to 8500' without a level off for cooling in these hot conditions. It must be noted, however, while I did not level during climb to augment cooling as in the past, I did manipulate rpm and airspeed to keep coolant temp below 230. Best rpm was 2300 and best airspeed 100-110 KIAS. At least that is what worked today. The EIS 230 coolant temp warning came on a few times as I tried different rpm's and speeds.
These are the numbers recorded. This is with 2 original H4 radiators and a front mounted oil cooler. Also, the right inlet side was closed off forward of the PRSU but not on the left side.
Climbing through 4000' OAT 88F.
Oil Temp = 191 Coolant temp = 227 Gear Box temp = 194
Climbing through 6000' OAT 87F.
Oil Temp = 199 Coolant temp = 228 Gear Box temp = 204
Level at 8500' OAT 76F.
Oil Temp = 202 Coolant temp = 228 Gear Box temp = 214
After 10 minutes at 8500, full throttle 2100 rpm.
Oil Temp = 187 Coolant temp = 217 Gear Box temp = 205
Not too bad for a totally rotten hot humid day in the mid west. There's no doubt these radiators are most adequate for the H4 as many guys have reported. They are OK for the H6 but the new larger units will be better.
One further note. I flew this mission with 87 mogas with 10% ethanol. It tested at 47 kPa's in the hanger at 95F. This fuel had a little 100LL mixed in, but most of it was mogas. Vapor pressure of fuel has no relationship to octane. I had some 93 mogas earlier this year that tested at 34 kPa's.
If you use mogas, it must be vapor tested before each flight.
Dd
RV-7A
N707DD
Dd
RV-7A
N707DD
