Hi all, just getting through an entire IFR panel retrofit in our RV9A and stuck on the very final part... getting ADS-B out going. Particularly, on the EchoUAT app. It's not showing any position or altitude data from my GPS 175 which is the intended position source.
Here's my setup:
- EchoUAT is mounted in fuselage next to pitch AP servo.
- Shielded AWG #22 wire between GPS 175 (Pin 7, RS-232 TX #3) to EchoUAT (Pin 6, COM2 RX). This run is about 6ft long along the pilot side.
- GPS 175 TX3 is set to transmit ADS-B+ Format 1
- EchoUAT COM2 rate is set to 9600
- EchoUAT COM2 format is set to ADS-B+
- EchoUAT and GPS share a common power ground
Troubleshooting I've done:
- EchoUAT is on
- EchoUAT LED is flashing green
- GPS 175 has a fix and knows where its at. Is also transmitting perfectly to my G3X.
- The ADS-B+ signal from the GPS is making it to pin 6 of the molex connector that goes into the EchoUAT. There is a voltage on that pin that is similar to when I measured it at my G3X when outputting the ADS-B+ format to it.
- I've tried every baud rate for COM2 on the EchoUAT app
- I tried rewiring pin 6 on the EchoUAT to go to my G3X and have the G3X output NMEA normal format (tried 4800 and 9600). I setup the EchoUAT COM2 settings accordingly.
- EchoUAT is connected to the app and isn't a complete brick. With my GTX327 hardwired to it, I could change the squaw codes and see the change on the app.
Not gonna lie here guys, I've run into a complete wall and I don't see many other options. I also talked to Uavionix for about an hour with no result. Before I quit and buy a GDL-82 or TT-22, anyone have some sacred tip? Could the app be wrong and the Echo actually is processing that GPS data? Do I need to be in the air for the GPS data to show up on the app?
Here's my setup:
- EchoUAT is on
