FlyingDiver
I installed the prop and set the blade pitch. The KAI said to torque to spec, so I did (220-240 in-lb). Then I set up the spinner and match drilled. Now I need to take it all off to install nutplates in the spinner supports. I can't get the bloody prop hub loose from the flange. See the pics.
How do I get this off without damaging anything? I don't think using a pry-bar is an approved method. Help!
