Italiancowboy
I have the Dynon HDX system and flying home yesterday got the big red "X" on the Manifold Pressure display (system is about 5 years old and 300 hrs).
I assume it the MAP sensor as everything else worked normal (MAP must just go to monitoring and not used in any engine performance software).
MAP sensor is mounted on the engine side of the firewall which Dynon says is ok but Van's installation on MAP sensors says to put it in the cabin side of the firewall (less harsh environment).
Questions:
Anybody out there have a Dynon MAP sensor failure ?
What are the causes ?
What are the ramifications ?
Questions:
