Graham
hi All,
I am close to first engine runs on my RV6, 0-320-D1A & FP Sensenich prop with the RH Mag replaced by a Light Speed Plasma II+ system. The LSE Manual states that when their systems are installed the alternator must have over voltage protection.
I have a Vans supplied (in 1999) 60A alternator.
There has been much written about the need (or not) for separate overvoltage protection with some electronic systems. I have studied much of it but currently rather confused.
My question is simple.
Has anybody flown this combination of alternator & any LSE Electronic Ignition system? If so, have you had any bad experiences due to, or thought to be due to, overvoltage?
Plse advise your config & experiences, good or bad.
Any other feedback would be appreciated.
many thanks in advance
Graham
New Zealand
hi All,
Graham
New Zealand
Hi Graham;
I built an RV7A in 2006 & it had dual LSE & the alternators Vans used to sell, but discontinued. The LSE is a long story, but in regards to the alternator, I will post the internal regulator I changed out here for you.
I can go into greater detail, but these internal regulators are either C, D, or S. IIRC the Vans used to supply the 60 amp Denso with a regular “D” ,, Dummy Lug & I have swapped these out to a Toyota Forklift regulator the is an “S” ,, Sensor
Here are the “Specs”;
The 60 amp Alternator Vans used to sell;
Nippon Denso - Lester #14684
The internal regulator I choose to swap to;
Transpo IN256 “Sensor”
https://www.ebay.com/itm/115173234279
Hi Graham;
Yes... Would you, please.
