GrinchF16 Well Known Member Jan 19, 2024 #1 Do you guys that have this Cowl Pin Cover installed have a straight hinge pin or do you have the flat part that you can screw down?
pazmanyflyer Well Known Member Jan 19, 2024 #2 GrinchF16 said: Do you guys that have this Cowl Pin Cover installed have a straight hinge pin or do you have the flat part that you can screw down? Click to expand... Mine is straight with a loop at the wire end under the cover so you I remove/install it.
S SteveHicks Active Member Jan 19, 2024 #3 I used the flats and made a recess for them to fit under the cover on my RV14 ... see this blog page.
MED Well Known Member Jan 19, 2024 #4 I cut off 3/4 of the tab leaving just enough to grab with a small vice grip. The tab remnant fits nicely under the cover.
9GT Well Known Member Patron Jan 19, 2024 #5 I made mine out of some thrift store tablespoons. Cut the handles off, some minor grinding on the sander, and then a polish on the wheel. Aerosport's look better of course, but I am frugal and enjoy fabrication.
