alpinelakespilot2000
I have the Van's A-510-2 keyed ignition switch. I'm using 18AWG shielded wire. Van's drawing shows that the shield is separated from the P-lead at the magneto end but it shows it unseparted at the switch end. (There is only one connection to make at the switch per Van's drawing.)
To put a ring terminal on the switch end, should I just strip the insulation and shielding off and crimp the terminal just as I would with an unshielded wire, or do I need to do something special with the shield at the switch end? (Specifically, I'm wondering if I somehow need to make sure that the shield can't come in contact with the main wire or terminal.)
Thanks.
Thanks.
