WH-00059 phone cable
jcbarker
I am attaching my aft fuse to the forward fuse. It's been so long I can't remember what the WH-00059 phone cable is used for? It's routed from the F-01414 Aft Deck forward. Do I need to bring it up behind the panel?
One end at the elt, the other end at the elt remote switch in the panel.
oh, yeah. The ELT! Does it mount on the aft deck? Is it called out in the KAI somewhere or does it depend on which ELT you buy and you figure it out on your own.
It Depends
The ACK brand ELT uses the phone cable to connect the unit in the tailcone to the manual switch on the panel. I opted for the Artex unit which uses a shielded pair to make the connection. I don't know about other brands.
Unfortunately I don't have all the digital plans.
Note to everyone: With access to Van's "store" temporarily closed, You cannot access the digital plans or order the memory stick.
