Yep, you are correct. Useful bits and pieces left over from the build. It is a wedge after all.Part is used on the trailing edge of the elevator between top and bottom skin. Rudder uses a similar construction. I believe designs other than 9/9A use a single skin folded at the trailing end.
Terry, CFI
RV9A N323TP
