hcccs
I was high speed taxying my RV4 and at the end of the grass strip I turned round and taxied slowly back and noticed that nothing happened whe I pressed right rudder pedal. If I let go the plane pulled to the left and I had to put on some brake to keep a straight line and it was so bad I had to step out and make sure the tail wheel chain hadn't come loose but it hadn't. After a while everything was normal again and then it happened again. When turning round the tail wheel is free swiveling and going straight again the spring loaded sliding key should engage to keep the wheel straight. I'm wondering if it did. Has anyone experienced this?
