Would like a recommendation on what simple servo tester to buy. Thank you.
V Vansconvert Well Known Member Nov 12, 2023 #1 Would like a recommendation on what simple servo tester to buy. Thank you.
Brantel Well Known Member Nov 12, 2023 #2 What servo? Many different types and technologies out there…
E ewumnrr Well Known Member Nov 15, 2023 #3 Vansconvert said: Would like a recommendation on what simple servo tester to buy. Thank you. Click to expand... In case you are talking about PWM controlled servos like the ones being used in the RC world: I really like this one: https://www.servocity.com/servo-commander/ It supports 4 different servo input signal ranges. If you want to run it from 12V, use this: https://www.servocity.com/6a-bec-vo...-input-5v-6v-8-4v-12v-output-xt30-connectors/ You probably want the connectors, too: https://www.servocity.com/search-results-page?q=3803-0102-0005 /M
