glen25781
Member
Hey guys and gals,
Pulled my awesome little bird out of the hangar this morning (6A with an O-320 Lycoming) and it wouldn't start. Prop turned over just fine ... the battery is only a few weeks old and cranking is strong but it just wouldn't fire..not even one little sputter. Outside temp here was colder than usual here in the Florida panhandle - 45 degrees - but I don't really think the temp was an issue.
I usually give the throttle a couple of pumps before I start it and then keep the throttle open about 1/2 inch with the mixture rich and it always fires right up easy as pie...until this morning. Ended up and cranking and cranking to no avail. Called my A&P and he said I may have flooded it so try this: a hot start procedure where you pull the mixture full lean, open throttle about halfway open while holding the brakes and try again til it fires, then quickly full rich.
I Tried that several times, then gave up and decided to let it rest overnight, throw the trickle charger on the battery and try again tomorrow.
Any ideas?
Thanks in advance,
Glen
Any ideas?
Thanks in advance,
Glen
