My RV6A originally had a napa vr166 regulator. It was connected with the "I" terminal empty, "A" terminal connected to the "S" terminal then to the stator and the "F" terminal to the field of the alternator. The case is grounded to the firewall. The napa regulator lasted for several years and then began to fluxuate from 12 to 14.5 Volts about 3 times per second.
I have switched to several brands of the VR166 regulator and they are good to start but soon fluxuate followed by failure in about 2 to 3 hours. The regulator is located on the firewall, engine side. I added a heatsink to the latest regulator but it only lasted about 10 hours.
Has anyone experienced this problem and have a solution? Some regulators just have a field and battery connector. Can I connect one of those to my alternator field and stator? Has something happened to the alternator causing the problem?
