Vansconvert
I have a rod end on my throttle cable going to the arm on the fuel injection unit. It has the large washer correctly installed directly under the bolt head, and a combination of three small washers, a short bushing and a much longer bushing. I understand the bushings go on each side of the rod end. However I don?t understand why the one bushing is so much longer than the other, like about 1/2 of an inch which results in quite an off set connection.
Could someone provide a picture of your setup? Or a picture of what Van?s sells in their bearing hardware kit? Or a description of your setup?
I have the Precision fuel injection unit. Thanks much.
