Oil drain tube
g zero
I had the #2 oil drain back tube crack on a recent trip . Was able to trim it back and re -flair the tube and continue on .
Trying to locate the Part Number….its an Angle Valve IO-360 C1A …any help would be appreciated.
Try the Lycoming Parts Catalog:
Page 3-7
Part number: 68760
I appreciate the information.
I think this crack started a while back …. I’ve had a slight oil leak that I couldn’t chase down …. Pretty sure this was the cause.
Ordered all 4 from Air Power …. $140 .
I figured if 1 cracked …..
That is good pricing compared to other sources. A couple on mine have distorted flares and I will probably replace them and lengthen them slightly to avoid interference with the baffle ties. I will also be replacing the rubber hoses and using constant tension spring clamps while at it.
