Anyone know the RV-6 mount for a parallel valve IO-360 would work for an O-320E2D?
L llohrman2 Member Feb 11, 2023 #1 Anyone know the RV-6 mount for a parallel valve IO-360 would work for an O-320E2D?
G gasman Well Known Member Friend Feb 11, 2023 #2 That really depends on the type of mount on the RV6 now. If the mount pads are tilted inward, and the pads on the O360 are machined at an angle, this is the most common and it should work.
A Avanza Well Known Member Feb 12, 2023 #3 Your engine has the Dynafocal 1 engine mount configuration. So you are looking for a parallel valve 180 hp with Dynafocal 1 engine mount configuration. Good luck
