leading edge landing light drawing
Hi fellows,
does anyone have the drawing for the leading edge landing light cutout? I had them when I started but have to renew that part due to a taxi incident.
May be as pdf.
Thanks in advance
Stephan
PH-LRV
AOG
Is this what you are looking for? You didn't say what aircraft. This is for RV-4/6/7/8.
It doesn't say in these instructions but the FAQs on the Duckworks site say to mount these lights in the most outboard bay only, for structural and lighting performance reasons.
  • Duckworks install instructions RV-4 6 7 8.pdf
The pattern will vary with the model. If you're using Duckwork's assembly, contact them for the pattern - it should have been included in their kit. If it's another vendor, best to ask them.
If anybody needs a 1:1 scale template for the Duckworks cut out for an RV-3/3B wing I have it in CAD and could provide it as a PDF file.
The reason they are different by model is the leading edge radius varies somewhat by model.
Jim
Stephan. No problem. I will send you one. But keep in mind this is for the RV-3 which has a tighter leading edge radius.
PM me your email address.
