Fuel sender reseal - how much proseal?
Getting ready to pull both fuel senders and plates as they are seeping. Appears that I lucked out (?) in that they have no proseal on them but they do have cork gaskets. At least the cleanup should be easy. Doesn't seem like I'll need a bunch of proseal to do this. Will one of the 3.5 oz. tubes be enough? I'm also concerned that if you mix up that tube, you have a limited amount of time to get both done.
Should I just buy a quart and mix it as needed?
