Fuel Pressure and Delivery on Lycoming and Continental Engines
rv6ejguy
This is a question for the engine overhaul guys. What is the maximum fuel pressure and delivery from the pumps on the TIO-540 and TSIO-550 engines?
Looking at fitting EFI/ FADECs to these and wondering if the engine driven pumps are up to the task. We're needing 65 psi and 450 lbs./ hr. to be safe on the race engines. Can these pumps be tweaked to do this?
Never tried going for a max. The TCM pump on the 550's is setup for around 35-40 psi with a flow of 36-45gph. The pump on the Lycoming's might make 65 but normally set around 50 psi with flows anywhere form 30 gph to 45 gph.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at you own risk."
