wirejock
I'm confused. First, I will clarify. I have two HDX. I installed a two port USB so the data ports would be accessible on the instrument panel. Glad I did. It seems they get used a lot.
Dynon HDX questions...
1. The Dynon HDX comes with a USB mini 32mb flash drive. I have two screens so two flash drives.
The updates have to be done individually.
I see no reason why each one has to have its own flash drive update. Files are the same.
I assume using one drive can be used to update each screen?
2. The Seatle Avionics Data has to be on a USB Flash Drive plugged into the HDX when in operation. It's a lot of data so I bought a 128G and formatted it FAT32. Yes, it can be done quite easily. I assume the system needs a flash drive for each HDX, but I could be wrong.
Do they share the data or do you keep one in each HDX USB port?
