pilot28906
I drilled the rear wing spar to the fuselage several years ago however recently see where most finish this hole with a reamer for a better fit. I drilled mine with a normal drill bit. I followed all the directions on wing sweep, incidence, and hole edge distance is all good.
Is the drill bit OK or do I need to go up in bolt size and use reamer with close tolerance bolt? This may be a question for Van's but thought I would get your opinions.
