Yep using them on my IO320.
Kit from SDS has the hose and the clamps. The pipe to head "O" ring setup is simply fantastic.
All working fine.
http://www.sdsefi.com/sdsaero.htm
Is any one using Constant tension band hose clamp for the intake tube?
Im using them on my oil return lines from my rocker boxes and in 3 yrs not a drop and zero maintenance.
Any reason why we wouldn't want to use them on the intake tubes?
Tim
Can you tell me what size clamps you used on the rocker box oil return lines and maybe provide a link if possible.
Thanks.
Thanks.
16 or 17 mm wouldn't fit on my hose. You will need to confirm the specs on the hose and the clamps to ensure a proper fit.
Mine from Belmetric fit perfect.
I just took the hose to the local NAPA store, they got me the correct size clamps-----possibly for a fuel injection setup IIRC.
The link to the clamps in that post was outdated and I just edited it. You'll want to get 16mm clamps instead of the 17mm ones the old URL went to.
Are these little clamps really $10 each? The Amazon link listed them for right at $10. I thought it was probably for a box of at least ten, but that price appears to be for each one. ...
The description indicates "10Pcs"
